Onkyo M-282 Deal @ Accessories4less.com
adk highlander
adk highlander
Sith Lord
That is a good price for a referb. I have one of these at home pushing 3 zones in my house and one of the Integra versions in my office and they have been great. Low noise floor as well.
afterlife2
afterlife2
Would this add more power to a 5.1 setup or just 2.0 for vinyl? Sorry for my naivete with amps.
adk highlander
adk highlander
Sith Lord
Unless you had a very underpowered receiver I would not use this in a 5.1 setup. If you had a preamp and were looking for amps to run a system then it would be fine. I use it for my 2 channel system at work (I have an old marantz pre-amp) and for zones in my whole house system.
anamorphic96
anamorphic96
It's the same amp section as the 100watt receiver the TX-8555. However the 189.00 asking price is not all that great in my book when I can get a new one for 229.00 from authorized dealers.
ImcLoud
ImcLoud
I had one, it has the same sound as med grade onkyo receiver... They dont like 4ohm loads though... I had Mine in the garage and it used to shut off when ever I pushed it... Not a bad unit to add to a current receiver for a little more headroom... Now instead of 200watts for your 5.1, you have 200 watts for your front 2, and 200 watts for your 2 surrounds and center... I like the Dayton apa150 better though, its smaller, can be bridged, had auto on feature, built in xover, 4 ohm capable, Only $158, and to me sounds cleaner...
Matt34
Matt34
Moderator
Is the Dayton still available? I have the Emotiva BPA-1 that it's based off of over here in Afghanistan with me. Used to have three of them but broke the speaker inputs on two of them during a move.:mad:
KEW
KEW
Parts Express has them at $158 shipped. Appears to be standard stock item.
