I made a mistake of buying a home theater receiver when i should of bought a stereo receiver. I bought this 3 or 4 months ago and it has everything with it except the subwoofer(sold that to a friend who needed it for his HT system) Everything is in mint condition with the box. Its originally $400 but I'll sell it for $200 + $15 shipping. Its had about 9 hours of use and thats it. All the equipment is black also.
you get the receiver, 6 speakers, and the remote control with all the accessories that came with it, instruction manual,cables, radio antenna, batteries, all in original packaging with styrofoam.
Receiver
*Stereo RMS Power 100 watts x 2, .08% THD, 1kHz, 8 ohms
*Surround RMS Power 100 watts x 6, .08% THD, 1kHz, 8 ohms
*No. of Channels 6.1
*AM/FM Presets 30
*Input Optical Audio: x1
*Coaxial Audio: x 1
*Composite A/V: x 4
*Audio (RCA): x 6 (4 A/V)
*S-Video: x 3
*Output Composite Video: x 2
*Headphone: Stereo mini x 1
*S-Video: x 2
*Surround Format Dolby Pro Logic IIx, Dolby Digital EX, DTS, DTS ES Discrete 6.1, DTS Neo:6, DTS 96/24
*Dimensions (WxHxD) 17.1 x 5.9 x 14.5" (435 x 149 x 365mm)
*Weight 19.6 lb (8.9 kg)
Speakers
*Configuration 1 x center, 5 x bookshelf
*Shielded Yes, magnetically shielded
*Speaker Type 2-Way
*Drivers Front: Woofer: 3.1", Tweeter: 0.8"
*Center: Woofer: 3.1" x 2, Tweeter: 0.8"
*Surround: Woofer: 3.1", Tweeter 0.8"
*Dimensions (WxHxD) Front: 5.8 x 7.9 x 4.0" (147 x 200 x 102mm)
*Center: 14.8 x 5.0 x 5.2" (375 x 127 x 132mm)
*Surround: 5.8 x 7.9 x 4.0" (147 x 200 x 102mm)
*Weight Front: 2.0 lbs (0.9 kg)
*Center: 1.6 lbs (3.9 kg)
*Surround: 1.5 lbs (0.7 kg)
*Enclosure Bass reflex
