Heads up, headphones fans!
If you are in the market for a new pair of headphonee, be sure to check out the Onkyo ES-CTI300 (BS) Headphones. As we expect from an Onkyo products, these combine very nice characteristics and comfort with an iOS-Certified 6N copper cable that allows you to control media playback and manage calls from compatible Apple devices. These headphones feature large titanium drivers which feel solid and offer impressive sound detail. They are compact for everyday use and have flat-folding aluminum ear-cups making them easier to carry/store. The included cable is encased in a transparent elastomer coating to minimize touch noise and it is connected to gold-plated MMCX connectors. Another nice feature is that the connectors are detachable and let you swap out the cable if it gets damaged.
The ear-cups are made from highly rigid aluminum, taming the resonances that can lead to distortion. Because of its strength, the driver enclosure walls can be thinner, increasing internal volume which improves bass reproduction. The connector housings and hanger arms are also fabricated in aluminum to withstand extensive use.
For better comfort and performance, these headphones feature soft leatherette earpads to minimize sound leakage and ambient noise. Combine that with a padded, adjustable headband and you know you are set for hours of musical joy. I don't know about you but, I'm giving them a try.
What do you say? Are you interested?
FEATURES:
- Driver Housing & Arms: Aluminum
- Cable: 6N Oxygen-Free Copper (Detachable)
- Inline Control: Yes (with mic)
- Tangle Resistant Cable: Yes
- Connectors: Gold Plated
- Folding Design: Yes
- Headband: Yes (Adjustable, Padded)
- Earpads: Leatherette
SPECIFICATIONS:
- Driver Size/Type: 40mm/Titanium
- Frequency Response: 10 Hz–27 kHz
- Maximum Input Power: 1000 mW
- Output Sound Pressure Level: 97 dB/mW
- Nominal Impedance: 32 Ohms
- Cable Type: Oxygen-Free Copper with Thick Elastomer Sheath.
- Inline Controls: X (with mic)
- Cable length: 47-1/4" (x1)
- MMCX Connector: Gold-Plated (Detachable).
- Stereo Plug: Gold-Plated 3.5 mm L-Type.
- General Weight (without cable): (8.3 oz)
