Onkyo announces active speakers with Wi-Fi and DLNA support
BoredSysAdmin
BoredSysAdmin
Onkyo has announced the GX-W100HV, a pair of traditional bookshelf speakers with a twist: DLNA support baked into the cabinets. The master speaker incorporates 802.11 b/g/n Wi-Fi, and relies upon Wi-Fi Protected Setup (WPS) to connect to your router — there's no way to input an SSID and password here. Once they're connected, the speakers broadcast their availability around your network as a receiver for any DLNA-capable app on your PC, phone, or tablet, and are able to render DRM-free MP3, AAC, or WAV files. If you want to incorporate them into your existing sound setup, the speakers also include optical and analog inputs. These aren't the first DLNA-capable speakers we've seen, but the growth in products like this allow the industry standard DLNA to act as a true rival to Apple's AirPlay which currently dominates the discussion surrounding ad-hoc wireless speakers.
In terms of audio, the speakers are capable of outputting 15 watts per channel, with each cabinet carrying a 12cm A-OMF woofer and 3cm tweeter that Onkyo claims has been specially tuned for voice. The front panel of the master speaker carries an input selector, two-band EQ, and a headphone socket. Although Onkyo quotes a flat frequency response up to a high range, its low-end seems to be a little lacking — the frequency response bottoms out at around 50Hz, though the ported design ought to keep it flat to that point. The GX-W100HV is set for release in Japan on the 18th of February for a pricey ¥40,000 (about $520).
via: Onkyo announces GX-W100HV active speakers with Wi-Fi and DLNA support | The Verge
Hi Res front here:
http://av.watch.impress.co.jp/img/avw/docs/510/856/onkyo1.jpg
and back here:
http://av.watch.impress.co.jp/img/avw/docs/510/856/onkyo2.jpg
agarwalro
agarwalro
They look like glorified powered computer speakers to me. And,
Powered != Active.
BoredSysAdmin
BoredSysAdmin
Powered != Active.
They do
And about the 2nd part: I did copy&paste from Verge.
I was on the borderline myself about it, but - I see no speaker level connections on the right monitor, only line level connection - which means that left is independently powered.
That still doesn't mean they are truly active as in active crossover and separate amps for each driver, but it is possible ;)
