onkyo 875 or Integra 7.1...?
Sounds Good
cant decide which one i like... i think i might go up to my local integra dealer (about 40min drive) and check out the 7.1... anyhow looking for some advice..
i do about 80% movies 20% movies
my future plans for speakers are a set of Ascends and something from svs, i would like to get a pb12plus/2 but one thing at a time... might hold out for the ultra 13...
thanks
875
Power Output
140 W + 140 W (8 ohms, 20 Hz–20 kHz,
THD (Total Harmonic Distortion) 0.05% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
Output Level and Impedance 200 mV/470 ohms (Rec out)
Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 20 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance -
Video 1 Vp-p/75 ohms (Component and S-Video Y)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
0.28 Vp-p/75 ohms (S-Video C)
1 Vp-p/75 ohms (Composite)
Component Video Frequency Response 5 Hz–100 MHz (-3 dB)
General
Power Supply AC 120 V, 60 Hz
Power Consumption 9.5 A
Dimensions (W x H x D) 17 1/8" x 7 5/8" x 18 1/16"
Weight 50.9 lbs. (23.1 kg)
7.8
Rated Output Power (FTC)
All channels
130 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.05% (FTC)
0.05% (Power Rated)
Damping Factor
60 (Front, 1 kHz, 8ohm)
200 mV/ 47 kohm (LINE)
2.5 mV/47 kohm (PHONO MM)
200 mV/ 470 ohm (REC OUT)
Phono Overload
70 mV (MM 1 kHz, 0.5%)
Frequency Response
5 Hz–100 kHz/ +1 dB-3 dB (Direct mode)
Signal to Noise Ratio
110 dB (LINE, IHF-A)
80 dB (PHONO, IHF-A)
Speaker Impedance
4ohm–16ohm
Video Section
Level and Impedance
1 Vp-p /75ohm (Component and S-Video Y)
0.7 Vp-p /75ohm (Component Pb/Cb,Pr/Cr)
0.28 Vp-p /75? (S-Video C)
1 Vp-p /75ohm (Composite)
Component Video
Frequency Response
5 Hz – 100 MHz, –3 dB
General
Power Supply
AC 120 V, 60 Hz
Power Consumption
9.5 A
Dimensions (W X H X D)
17-1/8" × 7-5/8" × 18-1/16"
435 × 194 × 458.5 mm
Weight
50.9 lbs. / 23.1 kg
aarond
with both being pretty much the same receiver in a different box and the 875 can be had for under $1k and I would be surprised if you could get the 7.1 for under $2.5k its a no brainer for me.
Seth=L
Seth=L
The Onkyo has a better scaler, no competition at all.
Sounds Good
i like the netune feature of the integra.. humm..
looks like 875 here i come... unless there is going to be a 876?
jostenmeat
The question is do you even need the scaler? I don't, though admittedly Im the rarity. Nice choices on speakers and sub. If that is any hint, Im sure you will choose your electronics wisely as well.
Sounds Good
thanks...
id really like to see what outlaw is going to come out with... but..
i would think as far as video prosessing goes i would think onkyo would be the best choice...
i just want to make sure it is almost future proof... but i guess good luck with that... i bought my ds777 with the same in mind... lol
just out of curiousity, what would be a fair asking price to sell my ds777?
Sounds Good
where would a good place to buy the 875 from?
davo
I wouldn't let the video scaler be the deciding factor. I got my 7.8 a few months ago and one of the first things I did was to bypass the video scaler. It's generaly accepted to let the tv do the scaling (assuming it's a half decent tv).
Having said that the 7.8 is the Integra variant of Onkyo's 805, not the 875. Some of the spec's on power etc will be slightly less than the 875, but not to worry because it willl still deafen you in your bunker made of couch cushions.:cool:
What's the price difference between the two where you are?
Seth=L
Seth=L
The Scaler on the TX-SR875 is better than most TVs.;)
Panjsheri
Onkyo has the Reon chip, so that should do good for your video needs!!!!
