Unless you are using the "Pure Audio" or "Direct" Modes, or if your speakers are set to "large", your crossover settings should be sending bass to your subwoofer even for 2-channel sources. To reconfirm this for myself the other day, I ran some tests with a CD that had a lot of bass. The subwoofer was active for all cases except when I switched to Pure Audio then it went to sleep. FYI - - I do not use the “double bass” option.
