Onkyo 702 code for Samsung 42" Plasma
BobK
I'm trying to setup the Remote on the Onkyo 702 to control all of the devices (TV, DVD, VHS, CD, Tape, Phono, etc.) Having a probelm finding the correct code (according to the Onkyo manual, it's a 4 byte code) that allows me to control the TV with the Onkyo remote. Does anyone have a clue or possible recommendation on getting the correct code?
Thanks,
BobK
Takeereasy
Takeereasy
Have you emailed or called Onkyo? From their website:
Who can I contact with questions about my Onkyo product?
Please contact our Corporate Headquarters at:
Onkyo USA Corporation
18 Park Way
Upper Saddle River, New Jersey 07458
Tel: 201-785-2600
Fax: 201-785-2650
You could also fill out their feedback form by clicking here. You can also contact the TV manf. and ask them if they know. Also remotecentral.com is a good site for remote questions. Good luck to you.
MDS
If there is no code listed for your TV or the one listed doesn't control all of the functions correctly, there is nothing you can do about it. Pre-programmed codes are nothing more than an index into a table that contains details of the protocol and numbers for each function to control the device.
You can learn from the tv remote to the Onkyo remote or better yet get a good universal.
BobK
18 Park Way
Tel: 201-785-2600
Fax: 201-785-2650
Thanks, I sent Onkyo a message asking them. Awaiting reply.
