rector
I am looking manual for ONKYA TX-80
for using this amplifier with 6 speakers with 4 ohm each one.
My question is it possible to use ONKYA TX-80 with 6 speakers ?
Or could you direct me where I could find some literature for dummies
how need to calculate load for this amplifier.
Thank you
Adam
Adam
Welcome to the forum!
Are you wanting to run all six speakers at the same time with that Onkyo? I haven't found the minimum recommended speaker impedance for the TX-80, but the power ratings for it are only listed down to a 4-Ohm load for two speakers.
The below image is blurry but is the best that I've found so far for the TX-80.
rector
Thank you Adam
It is really kindly from you for so fast answer
I really need to use these quantity speakers in office and the question, how I can use this TX-80 (existing) for 6(not existing) speakers may be with different impedance?
Any way, may be you know were I can read about calculation of audio load. I have some knowelege but probably not enough
Adam
Adam
Hi, again. My only source for that information would be searching the web. There is stuff out there, though.
Perhaps some other members here know some good resources and will chime in.
