One receiver, two monitors
Matt34
Matt34
Moderator
I just picked up a projector and would like to use it just for movies and my CRT for everyday TV viewing. How can I hook both of them up to my receiver(HK 330)?
ragged
split the video out signal from the receiver. regular composite video splitter should work with component cables. I don't know if hdmi/dvi splitters are available. not familiar with your receiver, but the video out probably has composite, s-video and component outputs, maybe hdmi/dvi? you might be able to use the s-video out to the tv, and the component out to the projector.
Matt34
Matt34
Moderator
Thanks for the help.;) I was going to try running both TV and projector off component but went the easy route and went S-video to the TV.
That would have been my suggestion. Send the best signal to the projector and the next lower to the TV.
ps. I would suggest changing your sig line
