On Wall vs. Sub/sta systems
G
George
Which will give an overall better sound.
I am looking at sub/sats like the B&W MT30 or KEF eggs vs. on walls like the B&W FPM's or the Paradigm Cinema 330's.
Your help, experiences will be appreciated.
It is for a family room where it will be predominantly for watching movies.
George.
mjhamre
When I was looking for on-wall speaker info online it was pretty tough. People came up with a couple of recommendations, but very few had heard them in rooms. I listened to what I could in stores, but again, there was not much selection and each store seemed to have one or two brands often in different rooms, making it tough to A/B.
The HSU Ventriloquist satellite system is one that I have seen recommended a number of times, and it is relatively inexpensive. Triad speakers were often recommended for on-walls, but I have not listened to them at all. There was a vienna acoustics speaker that I thought sounded pretty good, but I am not going to remember the model number off the top. I wound up with Gallo Reference AVs, but that is in a different price point than the speakers that you mentioned.
Good luck,
--Matt
G
George
Thanks for the help. It seems not many have actually listened to the two systems.
rick chavez
cable question
i have in wall speakers Totem 8" Mask speakers and need about 80 feet of cable. what should i buy? they will be hooked up to a B&K A V R 507 unit.
Sheep
Sheep
10ga wire.
As for the topic at hand, I would rather have a sub/sat system vs. on wall.
Placement is everything.
SheepStar
Davemcc
Davemcc
--Matt
You are so correct. I've been captivated by the Ventriloquist system and I don't know why. I have a need for something like it, so I'm going to go ahead and order a set right now.
Davemcc
Davemcc
Ordered the Ventriloquist/STF-3 package through electronicsforless.ca. Great deal, too. $738cdn + tax, free shipping. Waiting for delivery.
