Hello everybody!
It's my first post here. Live in Sweden, 37 y.o., and learning about sound now. Got a new pair of nice speakers, than a good amp, now i need a good room... You know what i'm going through... But it's fun! Especially if i sort this thing out.
The sound I get now is not great all. Bass is generally weak, mids very muddled, highs good but soon overpowering. Sound makes me tired quickly. Especially as the speakers need to play louder to get something less than highs out. Overall,
not a balanced sound at all.
I just discovered browsing the web that the room might be the cause of my sound problems. I’m ready to buy some good acoustic treatment. I’m a bit lost what to get, partly because of the ‘special’ speakers that I have. Let me just give you all the info I can think of – maybe you have some good piece of advice for me.
My room is 15.7 x 13.6 x 8.2 ft. The long walls are concrete, the others are soft. Back wall (where listening position is) and one side wall are covered with wood. The other side wall has a double-glass window 7.9 x 3.6 ft.
For furniture there is a leather couch, heavy, and is 7.9 x 3.6 ft. The carpet is thick and 6 x 9 ft. also some shelves on the front wall, in the corner. A plasma 42” in between speakers, with plasma pushed to the wall as much as possible.
The speakers are on the long wall, couch is immediately against the opposite wall. The speakers are 1.6 ft from the back wall, and 4.3 respectively 5.2 ft from side walls.
Can’t move furniture around at all, but can use 3 corners (both in the back and one in front) and put panels on all walls.
The speakers are Mirage OMD-15 with the quirky Omnipolar design with mids and highs shooting upwards and being 70% reflected and 30% direct waves. Cannot figure at all whether I should apply any treatment to the front of them room or not, or what. The manual says ‘Some damping treatment to treat the ROOM, not the speaker reflection points, can work well to reduce this problem… Do not attempt to add dampening materials to the first reflection points of the speakers! Omnipolar Speakers are designed to embrace such reflections and they are a crucial part in the performance of the speakers.’ A review wrote that ‘the Omniguides are canted forward, more sound energy is radiated forward than to the sides, and the least sound is directed behind the speaker’. Specs and manual available online if you google the OMD-15 (system does not let me to place a link unless i have 5 posts!!)
Please advise what treatment you think would improve this room. Am I stuck more or less with a square room with all the insurmountable problems that come with that? Just trying to set my expectations right.
Many thanks for any advice you might have for me.
Cheers!
George, Sweden
