K
kevinm2
Is there a major difference in sound, listening in stereo to an older receivers (late 1980s) of about 110W per channel versus the newer model manufactured today with same power rating?
If the amp section was designed properly back then, why not the preamp section? How is that more difficult?What about the preamp section? Has that not improved over time either?
I asked because, while my older Carver is a great-sounding integrated in almost every respect, it has an audibly higher noise floor than my newer Onkyo receiver (I prefer it anyway because it is a real powerhouse and ruler-flat with zero distortion.) I thought that this difference might be due to the preamp.If the amp section was designed properly back then, why not the preamp section? How is that more difficult?
And if it is not, then what? Can it be fixed for a reasonable price (where reasonable=small fraction of replacement cost)?You may want to get your S/N ratio tested to see if it is still in spec.
What do the numbers say about the noise floor?I thought that this difference might be due to the preamp.
I can say this, when I went from an analogue receiver to one that could process the digital signals I could tell a huge difference in bass output capabilty with the better output coming from the digital capable receiver. .
