Hi every one! Guillermo from Argentina writing here.
I have a newbie question for you. Strangely, i feel it should be a common question, but i cant find anyone on the internet with the exact same problem. I have a lot of questions for different possible setups, so I hear any recomendation from you.
Mainly, I'm trying to design a audio setup using an Old PC as the main source of Music. In descending order of importance, I'll also like to include a turntable, blutooth conectivity (for streaming from my cellphone) and connecting my TV to avoid using the integrated speakers. I alredy own a pair of (decent?) speakers. In any case, I'll improve them later (should i go for subwoofer?).
The most important part is then the PC. My old computer has no digital audio outputs, so I was thinking about using an external DAC to increase sound quality. In this context the only solution I found is to use an USB DAC (as the Dragonfly) and wire the analog output from the DAC to an analog input of an AV receiver, then the speakers. Then, my first question is: As the AV receiver includes a internal DAC, is there another way to get a digital signal out of my pc and conect it directly to a digital input on the AV receiver?
Next in importance is the turntable. I own one with a phono output, and i see that a phono to line pre amp is at least $150, but new turntables with integrated preamp are around $100 (example Audiotechnica). Most AV receivers dont have a phono input. The sound quality of the latter is much worst than the separate turntable + preamp?
Thanks a lot, and sorry for grammar errors. I hope my english is understandable enough.
Guillermo.
