Sirbuildalots said:
I just tried it last night and I got sound but no volume controll. From my Onkyo TX-SR502 I used the sub out to the HK 3370's main in and the speaker is connected to the regular speaker terminals. Am I doing something wrong here? Thanks for the help.
My guess is that the "main ins" by-pass the pre-amp so you're basically using the amp section as a separate power amp. The level would be set using the Onkyo set-up menu for the sub level.
A different way would be to use one of the H/Ks line level inputs (Aux, Tape, etc.). Then you have control over the level with the H/K's volume control as well (if that is what you want). My H/K integrated (from 1984) doesn't have pre-out/main-in connections, so I had to do it this way. IMO, it is *not* the preferable way.
