I need some opinions again... Looks like im not gonna try and get a cheap buy on a surround package ill just piece together my HT 1 piece at a time.. Seems like the smartest investment strategy.
So.... My fronts.
Can I get HT quality fronts for 500?? CDN? id rather not spend more then that. Unless its a huuge jump in quality... So you fellow canadians... where and what should I be getting you think.
This is what i want out of my HT..... I want the wall shaking bass, doesnt need to be real punchy because i wont be using them much for music just for theatre realy... but its gotta have some boom for those explosive movies. I want detailed sound... the difference between listening to these speakers is i want a large range in freqency especially in the high range.. i want to be able to tell the difference between these and my logitechs and as much as most of you audiophiles and phytes might not believe... those speakers are thx certified and thx has hiiiigh standards andthey do sound great... but a little bassy and muffled i think... prhaps it just might be the audio codecs that come with the videos i download im not sure. But, i do want some at least mid range fronts wether they are floor standing speakers or bookshelves wih a lot of oomph or just excellent satellites... i need some advice... please try and keep it within 400usd cuz if i get them from the states it will likely be another 50 to ship and id like it to be under 500cdn if i can help it.
Thanks guys your always a big help
Justin
