Well, Long story short it is fall time here in wisconsin so my outdoor fun is over! I have began tweaking my HT sys...after all the info found on this site I have made enough of a diff to trick my self into believing that I have bought a new av reciever. That being said I cannot stop at that, I hope a few of you can understand but I honestly cuncxlude that my HT sys is done lol! I have spent manny a dollor and time in my car pre house> I guess my Ultimate question is what would take my HT to the next level? I have all my speakers level matched with a RS DB meter (huge diff buy one and do if not yet) Buit like afor mentioned I need to still upgrade! What would take my HT to the "next (sonic) level? I guess a new AV recieve is not the answer still I am around the 2K price range I honestly like how my speakers sound.. I just want to make it better!
Here are the specs on my sides
frequency response 37Hz-20kHz ±3dB
power handling 150 watts maximum continuous (600 watts peak)
sensitivity 98dB @ 1watt/1meter
nominal impedance 8 ohms
tweeter K-105-K 1" (2.54cm) Titanium dome compression driver
high frequency horn 6" square 90°x60° Tractrix® Horn
woofer Two K-1083-SB 8" (20.32cm) Cerametallic® cone / cast polymer frame
Crossed over AT 60 htz
CENTER:
Response 45Hz – 30KHz
21Hz - 120KHz 60Hz - 30KHz
Cross over frequency 2.9KHz - 2.2KHz
Sensitivity (1W@1M) 91dB - 89dB
Nominal Impedance Ohms 6 - 6
Power Handling RMS (W) 120 500 Watts (R.M.S)
1000 Watts (Peak) 100
Drive Unit Compliment
2 x 6” C-CAM® Bass Mid-range. 1 x 25mm Gold Dome C-CAM® tweeter. 1 x 12” C-CAM® Sub-woofer driver featuring triple suspension and 3" long voice coil 1 x 6” C-CAM® bass/midrange driver, 2 x 25mm Gold dome C-CAM® tweet
Crossed at 80 htz
New speakers for front? Dedicated amp for front 3 channles?
Again TY for continued input
