JJRHOD
The ohms rating on a pair of bookshelf speakers I am interested in buying is labelled 4-8 ohms (the Micca MB42 bookshelf speakers) but my AV recivever is rated for 6-16 ohms (Sony STRDH550). Would these speakers be okay to use for left and right as well as surround speakers? buying on a budget plus don't have a lot of space, thank you.
It will work but at high volume levels the avr could shut down in self protection mode...
Why the Micca MB42 speakers particularly, you like the way they sound particularly?
KenM10759
KenM10759
I think the speakers would sound so horrible as to be totally unlistenable long before they got to the point that that receiver could go into protection mode.
Y
yepimonfire
I've hooked 4 ohm speakers up to receivers rated for 6 ohms before without any problem. Most speakers have varying impedance anyways. For ported enclosures impedance rapidly drops off below the tuning frequency, in sealed enclosures below the woofers fs. In a small bookshelf with a - 3dB frequency response down to 80hz it's not uncommon for it to present loads as low as 3 ohms on low frequencies. The best way to avoid this problem is to use an active crossover on the receiver and cross it over about 10hz above the - 3dB point.
Sent from my SM-G360T1 using Tapatalk
