TjMV3
TjMV3
<font color='#000000'>Okay,  I'm a bit confused on the &quot;ohm&quot; issue.
I really don't understand what it all means.
I have the Anthem MCA 50 Amplifier which runs as follows (from the Anthem site):
POWER OUTPUT
(Continuous RMS, 20 Hz - 20 kHz, &lt;1.0% THD, AC line voltage held constant at full load)
Impedance :     ¥ 8                ¥ 4                    ¥ 2
# of Channels Driven 1 All 1 All 1 All
MCA 50 :   225 W 180 W    370 W 265 W    535 W 340 W*
The speakers I want ,   are listed as follows:  &quot;Nominal Impedance:  6 ohm &quot;
Will this be a problem for my Amp or speakers? I don't see &quot;6 ohm &quot;  listed on my  Anthem MCA 50 specs.
Will they work well together?
Can my Amp drive these speakers?
Can my amp drive them efficiently?
I've been using the Paradigm Monitor 9 V.3's,  and they've worked well together.  But I'm concerned about the compatibility of these other speakers,  with the MCA 50.
I have a feeling that as long as the impedence falls between 8 and 2 ohms,  I'm okay,  and they will work just fine.  But I'm just not sure if I'm right.</font>
srrndhound
<font color='#000000'><table border="0" align="center" width="95%" cellpadding="0" cellspacing="0"><tr><td>Quote </td></tr><tr><td id="QUOTE">I have a feeling that as long as the impedence falls between 8 and 2 ohms, &nbsp;I'm okay, &nbsp;and they will work just fine. &nbsp;But I'm just not sure if I'm right.
</td></tr></table>
You are correct. The 6 ohm load will be a little less strain than 4 ohm, and a little more than 8 ohm. The amp will be fine with it.</font>
annunaki
annunaki
Moderator
<font color='#000000'>The amount of power you are likely to see would be around 222 watts rms with all channels driven. You would have no problems running a speaker of that resistance on that amplifier.</font>
TjMV3
TjMV3
<font color='#000000'>Thank you for your responses!
It has set my mind at ease.</font>
