Well, I called HSU and some person told me that if I don't experience surges that I should plug it into the wall. But she said that she doesnt know what the power center I have can handle. The monster power center that I have can handle 2775 joules. I also have my HK AVR 7300, DVD, VCR, and PS2 plugged into it. Do you think the power center can handle all of that?[/QUO
Sounds like you are more worried in your 15 Amp circut handle that load. That is why I like the meter on the H15 so much; it shows you how many Amps your equipment is drawing and what percentage of the 15 Amp circut you have used, and how close you are to maxing it out.
I have a Hsu VTF-III Mk2 plugged into my power center's SUB plug which was designed for a high current device, when I had it placed across the room I also had a Panamax power protector designed for Subwoofers; the protector also has In/Out RCA plugs for your cable which I did not use.
It is my understanding that problems can occure with using high current drawing devices such as Amps & Subwoofers with surge protectors that were not designed for AV use, such as a PC surge protector, because Amps and Subs on occasion have high current draws that the surge protector sees as a spike so it clamps down and limits the current. I have also heard that PC protectors have filters that can introduce noise into your system. In other words that "Free" surge protector you got from the office just ain't going to cut it in many cases!
