G
Gseries69
Hi, I'm in the midst of setting up my first system. I've run the wires through the walls and just found out that I did not use CL2 or better rated speaker wire so I am changing them just in case. I also ran them parrallel to the AC lines. Like I said...novice. My question is:
1 - since the signal in HDMI cables is so low do I need to worry about the CL rating on them as well? I purchased monster cables in a 12' length and paid almost $200 but I did not notice what the CL rating was.
2 - Is it OK to run the HDMI cable parrallel with AC lines or do I need to move these as well.
System:
46" Samsung LNT4671F
Yamaha RV661
Polk RM6880 speakers
Thanks much for any help you can give.
System:
Yamaha RV661
