I bought an Onky TSXR604 to go with my new Toshia HD-DVD player and now that the newness has worn off, I am not sure I'll keep this receiver.
I decided to listen to some traditional stereo music and watch a few normal DVD's. I will point out that the CD's and DVD's I am listening to are being played back via my Sony SD-DVD player that I used to have hooked up to my HK AVR240 and prior to that, HK AVR65 (circa 1998).
For some reason, this receiver is playing back LFE at a much lower level than my AVR 240 and AVR 65 that preceded it. I have spent the last hour testing so I know what I am hearing. With either HK hooked up to my speakers including an Atlantic Technology 12" subwoofer, I typically had the sub's input level set to about 11:00 and no db adjustment either up or down. Sound was as perfect as I have heard. With this new Onkyo receiver I have found that I have to be at least 2:00 to get even close to the same LFE. I have re-read the manual to see if I have a setting off but I can't find it. I did see the section about subwoofer input level but that only affects the direct input, not something you would get over optical.
If I increase the subs output by 5db's I get close, but then I get a boomy sound. What have others experienced with this receiver with regard to LFE? There really isn't another HDMI receiver in this price range so I am not sure what I could return it for should I decide to do that.
I would trade it in on another HK if they had HDMI at a fair price. The AVR 245 won't bring in audio over HDMI and the 445 is too much $$. Anyone like the Marantz 4001? How about Denon 2307 or a Yamaha model? Maybe I should return my Onkyo and wait to see what the CES has in store?
Any input is appreciated.
Greg
