Not getting Dolby Atmos
Deano_
Bought a CX oled and plugged it into Sony 800m2 Blu-ray player and my yamaha rx v683. Still am not getting Dolby Atmos. I’m sure it’s a setting somewhere I am missing and was wondering if anyone has any ideas. All my settings are either set to bitstream or auto in terms of audio.
everettT
everettT
Your signal path should be bluray>avr>display. If you use ARC to the avr you won't get Atmos and likely TrueHD either.
Pogre
Pogre
Are you sure the content you're testing with has atmos content? Also, even the stuff that has atmos content doesn't mean you're going to get a signal for the atmos speakers continuously. They don't see a lot of action irl. They're just for effects.
If he has a 4K system he will. The improvement in how ARC functions on the 4K rigs is night and day different and improved from the 2K. That is probably the greatest benefit of a 4K upgrade. It's as simple has pressing the Netflix, or Amazon Prime button on the TV remote and setting the pre/pro or receiver to TV audio and that's it!
Trebdp83
Only components with eARC will enable audio return channel without HDMI-CEC having to be enabled. TVs and receivers with ARC must turn on HDMI-CEC to enable ARC. With HDMI-CEC and ARC on, the receiver will automatically switch to the TV input to play the ARC content. Some receivers switch to the TV input almost immediately when powered on if ARC is enabled. ARC will not pass lossless audio though it may pass Dolby Atmos from a DD+ signal. Netflix requires devices decode Atmos natively and not just pass it through. So, some TV Netflix apps will output a DD+ signal without Atmos. Only discs have lossless Atmos from a Dolby TrueHD bed layer. This will not pass over ARC but is supposed to work over eARC. Some receivers will display Dolby TrueHD instead of Dolby Atmos if there are no Atmos speaker channels assigned to the receiver. The OP will not get Dolby TrueHD or Atmos from the blu-ray player if he is connecting it directly to the TV. The OP can send video to the TV with the HDMI 1 output of the player and use the HDMI 2 output to send audio to the receiver and will get lossless audio out of the receiver. However, if ARC is active for TV apps, the receiver will switch to the TV input when the TV is set to the HDMI input that is connected to the blu-ray player. The OP will have to manually swith the receiver to the blu-ray input to get the audio from the player back. There could be other HMDI-CEC issues with this setup. As was mentioned, the least amount of problems will be had if connecting the player to the receiver directly.
everettT
everettT
I didn't think his AVR handled it...
