Okay Adam, I think I get this. Let me see if I have crossover right....
Smaller speakers can handle the higher frequencies and lower frequencies are made of bass type sounds which goes to bigger speakers because they can handle it. So by setting my crossover to 120Hz, I tell the receiver to put anything lower than 120Hz to my sub so those sounds don't try to get pushed through my tiny 3.25 surround speakers and distort. Sound right?
I'm still a little confused on what phase is/does but I get the settings information that you told me. It doesn't really matter then which they are on but by setting either to normal/0 or rev/180, they are in effect playing in phase.
The other thing I wanted to inquiry about was my sound. I feel like my sound is decent overall but sometimes I don't feel like I get all of an explosion or something. I feel like it should be harder hitting instead of what I'm hearing. Is there some kind of setting I can change to make explosions more in your face?
Lastly, the PS3 does not bitstream DTS-MA or TrueHd to the receiver. It decodes it and then passes it LCM to the receiver. (This is what I understand anyway.) Would a device that can bitstream right to the receiver make a huge sound difference?
Thanks for your information. If you could just confirm to me that I am correct that would be really helpful. If you have other info on the other questions, that would be great as well.
