the sub is going to mainly be in the home, i tried to play with winisd for a few minutes but i dont really understand what changes what when i was playing with it, also what hz should i shoot for, and does any one have any input i might need to know for building a ported box, ive always built my sealed boxes out of 3/4" MDF with out any internal bracing, however i always use liquid nails and then screw them together to make sure they hold and are air tight
also this sub is currently in a .625 cu ft sealed box, and it seems that the sub is bottoming out when it was hooked up to a 150rms watt amp, which i found kind of odd considering the spec sheet has it listed as a 350 rms watt sub, the main reason i brought this up was, does the size and design of the box effect the power handling of the sub? i dont want to worry about damaging my sub when i have it hooked up to a powerful amp..
oh yeah this is what i have for t/s parameters
Vas 32.13 liters
Voice coil resistance 4.11
Voice coil inductance le @ 1 kHz 2.96
Driver radiating area sd 53.4” squared
Motor force factor bl 16.64
Compliance volume 1.36 cu ft
Suspension compliance 189 um/n
Moving mass air/air load 166.71 gram
Moving mass diaphragm 163.01grams
Free air resonance (Fs) 28.35 Hz
Max excursion .56
Voice coil high 1.5”
Magnetic gap high .39”
Mechanical Q 8.83
Electrical Q .44
Total Q .42
