Noob alert - Connecting a Sub
Savage40
So, I pre-wired for all of my speakers in my HT room. Well I ordered all of the Banana plug wall plates for each speaker and the large 2 gang wall plate for all of the wires where the receiver will be.
Well, all of the speakers have 2 ports (pos & neg) however the sub ports are a single component jack? Well, the wire I ran for subs is the same speaker wire I used for the rest of the speakers, I guess I screwed up and used the wrong wire? Not sure how the good subs connect, but my cheapie that came with my old Onkyo HTIB has a component plug in on the back and not the 2 posts that other speakers have.
So, is there a way to use the speaker wire I have in place or am I stuck?
Savage40
Which sub did you get?
Well, I haven't got one yet. I was leaning towards the Rythmik FV15 or FV15HP, but think for about the same money I am going to get 2 of the Outlaw LFM-1 EX's.
agarwalro
agarwalro
Just reread your post.
Unfortunately, except for fishing a sub cable, no solution jumps out. Even when you get a good subwoofer, RCA input is the preferred connection (and not the speaker level input).
N
Nuance AH
Any of those choices would be awesome IMO. How big is your room, though?
Can you re-run the proper subwoofer cable? Something like this is all you'd need (not sure what length so I just linked to the 25 footer):
Here's the master link to all the lengths:
Savage40
Well, the only problem is when I rebuilt my house after the fire, I had spray in self-expanding foam insulation sprayed in all of the exterior walls and the attic roof. The cable for the sub is in an exterior wall, so I guess I am going to have to get creative.
Thanks for the link!
agarwalro
agarwalro
If you have a baseboards, you can run it behind them.
