I've finally got my home theater stuff mostly up and running enough to test screen some movies, but am experiencing a problem with DTS-encoded movies. I've got the Yamaha HTR-5990 and a Sharp DV-RW340 DVD recorder/VCR. Movies play just fine in all of the soundtrack formats (Dolby 5.1 etc), but whenever I select their DTS option via the DVD menu, I lose all sound (until I switch back). The DVD player has the DTS logo and a digital audio coax connector, which I'm using to go to the receiver, which is obviously DTS compatible. Any idea what the likely cause of this is? I'm hoping my new receiver isn't messed up. I don't know if it uses some sort of dedicated circuitry for DTS that went out, but could leave everything else ok? I tried a couple different cables and several movies (Star Wars, Master & Commander, Band of Brothers) and had the same problem. The Star War Ep3 THX optimizer test worked just fine, BTW. Unfortunately I don't have another DTS-capable DVD player to test this with yet (but Oppo is on the way).
Any thoughts?
Kevin
