DHolley00
I was trying to setup my HT last night. I have had it setup before testing it out and everything was working fine. but had to re-install once the priming and painting was completed.
I setup up the rec. with the center and the two fronts last night, but for some reason I have no sound coming out of my centre speaker. all the connections are working cause I took the centre speaker and plugged it into both the left and right speaker and got audio. just for some reason when i plug the centre into the centre port... I get nothing.
Im not sure if I have a setting turned on/off which could cause the problem. like I said i had it working and nothing really happened to the reciever for to think that it was damaged since then.
the reciever is a SONY STRDG820 if anyone has experience with this problem or with this reciever... your help would be greatly appreciated.
thanks,
DH
thanks,
DH
