I really hope someone can help. I've exhausted all options that I'm aware of. I have a Pioneer VSX-43 receiver and I cannot get sound to come from the zone 2 speakers. I know they work because they used to be hooked to different receiver. I have them hooked to the Zone 2 speaker inputs on the back of the receiver and I'm also aware that I am limited to analog input, which actually poses another question. I'll get to that. Another detail is that I don't simply want to set them up as the "B" speakers because I want independent switching of sources. Now, that said, best I can tell the ONLY thing that should I should be able to use in zone 2 at this point is the tuner on the amp because everything that is hooked up is done so via HDMI. Question #1. Do you have to "set up" the amp to use it as a "zone 2 setup" instead of a "7.1 setup"? Question #2. If I hook a set of RCA cables into the back of my DVD player, will that negate the audio output of the HDMI or vice versa? I want to be able to use the "smart" features of the DVD player for Pandora and the likes, but I was wondering if it confuses the amp to have both HDMI cables and RCA cables running to the inputs of the specified component. Please help!!
