no sound from sub ?
rcpilot_971
I just hooked up my new velodyne DLS 5000 and Im not getting any sound Im using monoplace RG6 cable from my denon 3808 have set the LEF+ main
anything else I need to do
Thanks Tim
Thanks Tim
I downloaded the manual all 9 MB for you. Pages 28 and 29 are the relevant ones. You need to select sub yes, and then select sub + main. That is page 28. On page 29 you need to select the crossover frequency. One other thing make sure the sub is assigned to the correct zone, the same as the other speakers in the room. Good luck!
