Niles Audio PHD42 Wall Mounted Speakers
N
nadeaux
Anyone know anything about these speakers, only place to listen to these is 5 hours away. I was getting ready to order 3 Paradigm Cinema 220 for my L/C/R then came across a deal on the Niles for about the same price.
I've heard the Paradigm 110 so i'm confident the 220's will be good but i wanted to hear throughts on the Niles PHD42.
Should I take a change on the Niles, they are also 4 ohm so i need to spec a avr that can handle that extra load so that will cost a bit more.
N
nadeaux
any thoughts on Niles speakers in general? I've found a local place that has some of the Niles in ceiling and in wall speakers, do you think these would provide an accurate idea of what i could expect from the phd42's assuming i listing to speakers with similar speaker sizes and specs.
