So I will be moving into a new apartment and its a horrible place to have a theater room but I don't have any choice so I need some help with ideas for speaker set ups.
I attached a picture, its the best I could do. As for dimensions the room is about 12 foot by 12 foot. Now for the problem as seen in the picture I have to mix this with my dining room (stupid small apartment). So I need help with my 5.1 set up. The furniture (couch, table and entertainment center) are stuck where they are. Unfortunately, I also must use an entertainment center for my soon to be replaced flat screen because of it being a rented unit.
I have the speakers linked in my signature. I was planning on putting both floor standing speakers on the sides of the unit with the center on the wall above the tv
. As for the surrounds I am at a loss on what to do here. I was thinking put one on the side of the couch but I have no idea where to put the other as it should be closer to the table but I don't know if I should get one speaker stand for the other. Also, I was thinking about putting the sub in the corner staggered behind one of the tower speakers.
Other specs:
- The couch is 110 inches from the tv
- Above the third cushion in the couch (closest to the table) there is a window
- 91 inches from the door to the corner on the side where the entertainment center is located
- about 2 usable feet between the chair of the dining table and the couch arm
If anything else is needed to be know please tell me.
Thanks for all the help.
