Over the years, I've seen many expensive, but cheap looking audio products. Haven't you? While this is true, I've also seen many great looking products that aren't as expensive as they look. NHT's SuperBud Earphones are proof of this as they look much better than what you would expect from their $99 price tag. Way better!
The SuperBud Earphones are NHT's first entry into the earphone category. These babies feature high quality, dual dynamic drivers mounted coaxially providing smooth frequency response and good dynamics. They are housed in solid aluminum enclosures which were also balanced for long listening sessions. The included cable provides a play/pause/answer button so you can take your phone calls and has been covered with a non-tangling woven material for better durability.
A note from NHT:
"An important fact about in-ear phones is that they will sound slightly different to every wearer. This is because the shape and length of the ear canal is different in every human, which affects perceived response, particularly in the bass frequencies. If the ear tips don't seal properly, the sound can be "thin" or if the seal is too tight, the sound can be too bass heavy. SuperBuds are supplied with 5 different sized, latex ear-tips plus two free samples of Series 200 Comply (tm) acoustic foam tips which insure you have the proper seal. To make sure you get the response you want, we also supply a free parametric eq app (one for Android and one for IOS) so that you can adjust the response even further to your listening tastes." - NHT
Let us know what you think about these little fellows. One thing is certain..... I'm interested!
Click on the following thumbnails to zoom in.
