next upgrade.. a "12" sub
3db
3db
I watched "2012" on Blu Ray and this is a really good flick from a surround sound perspective. Now for the bass...I'm thinking my current setup is a bit lacking for deep bass. I currently own a PSB Subsonic 5 (not the 5i) which is good down to 32 Hz. I need something that will dig into the low 20s for around $500Cdn. Is this achievable for my budget? How difficult will it be to dial a 2nd sub into my system that would be able to dig deeper? Is this also achievable with a 7.1 receiver opposed to a 7.2 receiver?
billy p
billy p
Your to late!
I sold my pb10 last month. I would've worked out a deal with you for shipping to Ottawa for <$500.00. Supervij another local member bought it and from all accounts is very happy. I believe he tried to augment the svs alongside his Athena as p400 but thought better of it.
Cheers, Bill...:)
Matt34
Matt34
Moderator
If you can put together a 20" cubed enclosure, this will give you what your after.
http://www.creativesound.ca/details.php?model=QUARTET12(TRIO12)H
I'd look around the used market at your price, it's going to be hard to find good 20hz output otherwise buying new.
New option:
http://www.sonicboomaudio.com/pb10nsd-powered-box-subwoofer-10-nsd-series-woofer-black-p-5.html
I think the next best option for you would be an HSU sub in Canada. They should have distribution there as well. A VTF-2 Mk3 will probably be in the same range as a PB-10.
The PB-10 is an excellent sub too. I got output to 16Hz and pretty respectable output at 18Hz from mine.
annunaki
annunaki
Moderator
There is always the DIY route ;):D
A Dayton Ref. Series in a vented enclosure can do 20hz pretty well.
Some of the AE Speakers options are worth a good look. AV12-X with dual 15" passives will do 18hz easy at >105db anechoic. In room would be even more. The cool part is net enclosure volume only need be 3.0ft^3!
billy p
billy p
For an additonal 200.00 I could've had duals but I was already pushing the outer limits of my budget. But those numbers are insane IMO....:D
