Hello all. Well, a friend of mine offered to buy my sub I just built so I am going to build another one for myself, with 2 12's. I was thinking of trying to get as small of a footprint as possible with 2 12" dayton High Fidelity's and have them down firing and rear ported. First question of the project: by having them down firing, should I incorperate a base plate to reflect the sound outward (like SVS) or should I put it on cone perch deals like HSU... I ask this because one would think that with a sub firing down at carpet, some sound would be absorbed? Not sure, I like the look of a box sitting up on those little cone dealys but if it sounds better, then I will mount in on a base plate. And yes, the theater rooms is regular carpet.
Thanks
Brett
