Deprecated: Use of "parent" in callables is deprecated in /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php on line 431
Fatal error: During inheritance of JsonSerializable: Uncaught Error: Unknown named parameter $config in /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php:431
Stack trace:
#0 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(431): call_user_func_array('parent::has', Array)
#1 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(395): League\Flysystem\EventableFilesystem\EventableFilesystem->callFilesystemMethod('has', Array)
#2 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(128): League\Flysystem\EventableFilesystem\EventableFilesystem->delegateMethodCall('has', Array)
#3 /var/www/html/forums/src/vendor/league/flysystem/src/MountManager.php(311): League\Flysystem\EventableFilesystem\EventableFilesystem->has('install-lock.ph...')
#4 /var/www/html/forums/src/XF/Util/File.php(728): League\Flysystem\MountManager->has('install-lock.ph...')
#5 /var/www/html/forums/src/XF/Error.php(100): XF\Util\File::installLockExists()
#6 /var/www/html/forums/src/XF/App.php(2195): XF\Error->logException(Object(ErrorException), false, 'Template error:...')
#7 /var/www/html/forums/src/XF/Template/Templater.php(1234): XF\App->logException(Object(ErrorException), false, 'Template error:...')
#8 /var/www/html/forums/src/XF/PreEscaped.php(5): XF\Template\Templater->handleTemplateError(8192, 'Return type of ...', '/var/www/html/f...', 21)
#9 /var/www/html/forums/src/vendor/composer/ClassLoader.php(444): include('/var/www/html/f...')
#10 /var/www/html/forums/src/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/html/f...')
#11 /var/www/html/forums/src/XF/Template/Templater.php(1684): Composer\Autoload\ClassLoader->loadClass('XF\\PreEscaped')
#12 /var/www/html/forums/internal_data/code_cache/templates/l1/s5/public/thread_view.php(58): XF\Template\Templater->preEscaped('Next level afte...')
#13 /var/www/html/forums/src/XF/Template/Templater.php(1315): XF\Template\Templater->{closure}(Object(Rivmedia\GuestRedirect\Template\Templater), Array)
#14 /var/www/html/forums/src/XF/Template/Template.php(24): XF\Template\Templater->renderTemplate('thread_view', Array)
#15 /var/www/html/forums/src/XF/Mvc/Renderer/Html.php(48): XF\Template\Template->render()
#16 /var/www/html/forums/src/XF/Mvc/Dispatcher.php(458): XF\Mvc\Renderer\Html->renderView('XF:Thread\\View', 'public:thread_v...', Array)
#17 /var/www/html/forums/src/XF/Mvc/Dispatcher.php(440): XF\Mvc\Dispatcher->renderView(Object(XF\Mvc\Renderer\Html), Object(XF\Mvc\Reply\View))
#18 /var/www/html/forums/src/XF/Mvc/Dispatcher.php(400): XF\Mvc\Dispatcher->renderReply(Object(XF\Mvc\Renderer\Html), Object(XF\Mvc\Reply\View))
#19 /var/www/html/forums/src/XF/Mvc/Dispatcher.php(58): XF\Mvc\Dispatcher->render(Object(XF\Mvc\Reply\View), 'html')
#20 /var/www/html/forums/src/XF/App.php(2184): XF\Mvc\Dispatcher->run()
#21 /var/www/html/forums/src/XF.php(391): XF\App->run()
#22 /var/www/html/forums/index.php(20): XF::runApp('XF\\Pub\\App')
#23 {main} in /var/www/html/forums/src/XF/PreEscaped.php on line 5
Fatal error: Uncaught Error: Unknown named parameter $config in /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php:431
Stack trace:
#8 [internal function]: XF\Template\Templater->handleTemplateError(8192, 'Use of "parent"...', '/var/www/html/f...', 431)
#9 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(431): call_user_func_array('parent::has', Array)
#10 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(395): League\Flysystem\EventableFilesystem\EventableFilesystem->callFilesystemMethod('has', Array)
#11 /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php(128): League\Flysystem\EventableFilesystem\EventableFilesystem->delegateMethodCall('has', Array)
#12 /var/www/html/forums/src/vendor/league/flysystem/src/MountManager.php(311): League\Flysystem\EventableFilesystem\EventableFilesystem->has('install-lock.ph...')
#13 /var/www/html/forums/src/XF/Util/File.php(728): League\Flysystem\MountManager->has('install-lock.ph...')
#14 /var/www/html/forums/src/XF/Error.php(100): XF\Util\File::installLockExists()
#15 /var/www/html/forums/src/XF/App.php(2195): XF\Error->logException(Object(ErrorException), true, '')
#16 /var/www/html/forums/src/XF.php(205): XF\App->logException(Object(ErrorException), true)
#17 [internal function]: XF::handleFatalError()
#18 {main}
thrown in /var/www/html/forums/src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php on line 431
