bob16
Hi: I have just got a Denon AVR-2805 7.1 Receiver, I am making a theater room in my basement, the room is 350 square feet. I would like some speaker suggestions. I am leaning toward Athena, but any other suggestions would be appreciated. Also a big one is what sub to buy (3-4 hundred dollar range) thanks!
abboudc
Check out the Onix X-LS at AV123.
For a 3-400 sub, check out the STF-1 or 2 from Hsu. The STF-2 is on sale for about $320.
You should also check out the 1K Recommended System right here on Audioholics.
speakerman39
speakerman39
As an Infinity Primus owner I would have to recommend them. Very big bang for the buck. Be sure to look at the 360's, C25, and the 150's/160's you will be glad you did. Vanns.com has some really good deals. As far as subs go, be sure to look at the offerings from both Hsu and SVS. Both offer huge bang for the buck. Good luck in your decision. Let us know what you decide.:) :)
