Hello. I am a newby in home theater and I need some help. After much research I bought a Klipsch RF52 home theater system (2 X RF 52 floorstanders, an RC 52 center, 2 X RS 42 surrounds, and an RW10D sub). I am still setting everything up in my family room and I am confused with placement and hooking up of the sub (and everything else for that matter). I know that it depends on the acoustics of my living room but where is generally the best place for the sub? The diagrams I have from Klipsch says that the best place is upper and to the left of the front RF 52s. I can put it there against the wall, but there is a doorway about 1 foot away to the left. Will that affect the sound from the sub? If I move it, Does the length of run of the cable to the sub from the A/V receiver affect the quality of the sound of the sub in terms of ambient noise such as buzzes and hums,etc,? That is, should I get a 12 ft or a 20ft cable? Also, I have Left and right line inputs to my sub to connect to my A/V receiver, but I only have one output from my A/V receiver.Do I have to use the Y-splitter that comes with the sub cable or do I just choose right or left input on the sub? Thanks for your help, I need it!
