Newbie questions concerning acoustic measurements
SpiritMachine
I am interested in getting some objective information about the acoustics of my current set up in the hopes of making some changes for the better. I was thinking of using something like Room EQ wizard.
First question-do I need to get the radio shack SPL meter and a tripod?
Second question-I will be using a macbook and using the headphone jack to plug into my receiver so that it can transmit the tones. I think I was reading something about how using the headphone jack had too much noise. I don't have a computer with a dedicated sound card. Is there a better option?
Third question-Assuming I do all these measurements what can I do to improve whatever weaknesses exist? My current set up includes Klipsch front and mains and JBL sub and surrounds left over from a HTIB. My receiver is 5 years old (yamaha HTR-5660) and I am not sure how much adjustment you can even do with it. It does have an equalizer but I don't know how much you can play with the frequencies of the individual speakers but I am thinking none. I play CD/DVD/Blu-ray through a PS3. Right now I am not going to be buying any new equipment I am just looking to get the most out of what I have.
Any insight would be much appreciated.
no. 5
no. 5
Room EQ Wizard is a wonderful choice, I use it myself.
You do need a microphone, a Radio Shack SPL meter is the easiest option. A tripod is a good idea, as you need to make multiple measurements in multiple locations in the room; a few where the primary listener's ears would be and also at other listener positions (but focus on the main listeners).
If you don't use a good sound card a true measurement microphone and a calibration file for the sound card and the microphone the results will not be accurate. But for what you want to do, I don't think the inaccuracy will be a big problem, you will still be able to make some improvements, just keep in mind that what you see on the monitor isn't an exact reflection of what's happening in the room.
I don't remember hearing anything about a headphone jack being too noisy, I have heard that the frequency response of a headphone jack usually has low frequency roll off, so depending on where that starts it can be a problem. Also, a laptop may not handle the bit depth and sampling frequency of the signal from REW, but you can buy an external sound card, or find some software that works better with your hardware.
The only improvements that can be made relate to low frequency performance; you will be able to see and address issues in bass response. Mind you the only way to address the problems is to move the subwoofer, speakers or your chair (though it may not need to move far).
Now you may wish to fix more than just bass response, but it is not possible to see all acoustical issues with room measurements, nor is it possible to fix them all - especially since many (many) problems should have been (and can only be) fixed by the manufacturers engineering department.
bpape
I would agree. You don't need the ultimate in mic accuracy. Large room issues will be very apparent - as will changes in placment. You're more looking for relative changes.
Bryan
