Looking for input on subwoofer.
I live in Silicon Valley and my house is old, I think poorly constructed, sitting on clay. Shutting the front door makes the walls shake a little. Big truck going by makes the house shake a little. House is structurally sound, but no insulation, no plywood sheeting.
I'm not going to add insulation or plywooding for several years since stucco is good and wiring is old.
I'm choosing Hsu VTF3 Mk3 and the SVS PB12 Plus that's on sale. I want to hear movie soundtrack, not the house. I will not play sub at crazy loud volumes.
My floor standers go to low 40's, high 30's in my room and nothing shakes even at loud volume.
Does it matter which sub I get from standpoint of house shaking? VTF3 high output gives <25Hz extension, PB12 Plus high output gives <20Hz. For my case should I go for the VTF3?
Also, if I was having shaking, would a 20Hz or 30Hz FMOD high pass filter be able to help without hurting anything?
Any quick simple things I should be doing to tighten up the house for compatibility with a decent sub?
Thanks!
