Hello,
I recently set up a pc audio system, consisting of my pc, Musical Fidelity xcan v8p and AKG K-701. Problem is, I get a crackling sound when I listen to music. It's not very loud, but it seems to get louder when I raise the volume. When I connect the DAC to another pc, with the first pc running and every cable and device at the same place, the sound dissapears. So I guess it's not a cable shielding problem. Also, when my pc is freshly booted, I get no or little crackling.
My PSU (Seasonic M12D) also makes a (physical) whistling noise (probably due to a bad capacitor) so it's about to be brought back to the store. I'll be swapping PSUs tomorrow, to see whether the problem lies with the motherboard or the PSU. Could the PSU be causing electrical noise to the USB plugs (I tried plugging it into another slot and a hub)? Has anyone encountered such a problem? Any suggestions or thoughts will be greatly appreciated.
PS: My pc is running Windows 7 and Ubuntu 9.10. My other pcs (with which i had no troubles) run Windows XP and Ubuntu... well the previous version. Also, the crackling is not continuous, it's a periodical, short pause.
