spudz
Just found your forum and would like some advice. I've used message boards for help in buying cars and found them to be an excellent tool.
My wife and I are building a new home (just dug the hole -- footings go in next week). It's a large home (5,600 s.f.) on three floors (two above grade, with a daylight basement). It will include a dedicated home theater. We'll install our existing 5:1 surround sound system in our upstairs family room as well.
My real question is about whole-house audio. I want to have installed a simple, straightforward and reasonably priced system capable of handling at least four sources going to 4-6 zones. I'm not looking to shake the walls or impress the neighbors -- just have background music for dinner parties or for reading the paper in the morning. My main music source will likely be my PC, from which I access iTunes and Rhapsody. We'll also have satellite TV/audio and may add XM. We'll want a tuner as well.
NuVo seems to be popular among builders and gets reasonably good reviews. Given that I'm looking for a simple, reasonably priced system that delivers clear, clean sound, what is your opinion of this product (probably the Essentia line)? What others are worth considering? What pitfalls should we look for?
I will not be installing this myself -- it'll be done as part of the construction, so DIY ease is not an issue.
Thanks in advance.
Thanks in advance.
