Newbie needs help deciding an AV receiver.. thanks in advance.
HARDEEP SINGH
Hello guys,
I have just purchased a 5.1 harman kardon HKTS 16 BQ SYSTEM.
Is it possible to find a receiver with 120 watts per channel @ 8 ohms with 200 watts subwoofer.
HERE IS THE SPEC SHEET.
4 Satellite Speaker
■ Frequency response: 45Hz – 20kHz (–6dB) SAT-TS11 Satellites
■ Midrange transducers: dual 3" (75mm) cones, video-shielded
■ High-frequency transducer: 1/2" (13mm) dome, video-shielded
■ Impedance: 8 ohms nominal
■ Recommended power: 10 – 120 watts
■ Sensitivity: 86dB @ 2.83V/1 meter
■ Enclosure Type: sealed
■ Dimensions (H x W x D): 243mm x 100mm x 92mm (9-9/16" x 3-15/16" x 3-5/8")
■ Weight: 1kg (2.2 lb)
1 Centre Speaker (CEN-TS11)
■ High-frequency transducer: 3/4" (19mm) dome, video-shielded
■ Impedance: 8 ohms
■ Sensitivity: 86dB (2.83V/1m)
■ Enclosure type: sealed
■ Dimensions (H x W x D): 102mm x 241mm x 92mm (4" x 9-1/2" x 3-5/8")
1 Subwoofer (HKTS200SUB)
■ Low-frequency transducer: 8" (200mm) cone
■ Amplifier power: 200 watts RMS
■ External trigger voltage: 3V – 30V AC/DC
■ Dimensions (H x W x D): 353mm x 267mm x 267mm (13-29/32" x 10-1/2" x 10-1/2")
■ Weight: 9kg (19.8 lb)
WOULD YOU PLEASE BE ABLE TO HELP ME MATCH A RECEIVER FOR THIS ONE.
MUCH Thanks in advance.
HARRY.
The receiver doesn't need 200w for the subwoofer, it just needs a pre-out (a pre-amplifier output) for signal to the sub's built-in amp rated at 200w. You don't literally need 120w per channel for the speakers just because that is their maximum rating, a receiver with more or less than 120w per channel will still work fine. I doubt those speakers will sound good with that much power in any case, they are of limited capability for high spl. You might try this spl calculator to see the relationship for power requirements at your listening distance http://myhometheater.homestead.com/splcalculator.html
Choice in receiver is more about your budget and the features/connectivity you need, what are those? What other gear will you be using with the system?
