Hello, let me start by saying I checked into the Beginners & Audiophytes section, however, it was displaying 0 threads for some reason. I am definitely a beginner and would appreciate any help.
I need a little advice on what to do with my current setup and what options I have as far as upgrading go.
Currently I run:
Receiver: insignia ns-r5100
Fronts: paradigm monitor 9
Center: polk cs2
I just purchased 2 polk monitor 70's to use as my new fronts and was thinking about using the paradigms as surrounds.
I realize my receiver is probably garbage. I was wondering what I should look at to power these speakers for a reasonable price.
Also if I use the paradigms as surrounds I will have 25ft runs, is 14ga wire sufficient or should I use 12ga? Should I use 12ga for the polks that would be 5ft away from the receiver?
Finally, I have a paradigm ps 1000 subwoofer, but my old roommates messed it up. Im no expert so I dont know whats wrong with it, would it be cost effective to try to have it repaired (if it can be) or to look for a new subwoofer (when the time comes)
Thank you very much
