kaleo said:
Thanks for steering me in the right direction with those good questions. I'll try to answer them...
I have a 10 yr old Sony TV w/ S-video, but will replace it with an HDTV in a couple years, so I want to buy stuff now that will be compatible with the upcoming HDTV.
No problem, since it will be a while before you upgrade to an HDTV, I don't think that getting an upscaling DVD player will be a huge concern. Just get a DVD player that can do progressive scan and has component-video outputs and it'll work fine when you upgrade your TV.
kaleo said:
My music collection consists of CDs, cassettes, and soon MP3/WAV/OGG files as I also recently purchased a digital flash audio player. Not sure about listening to DVD-audio or SACD discs (these are expensive i hear, and I'm cheap
) which I know little about. I do have a new computer that can burn DVDs +/-, so i suppose I will eventually get around to utilizing that capability.
Since all of your music will be stereo only, there's no need to worry about getting a DVD player that has discrete 6-channel RCA outputs on the back, You'll be better off using a digital optical or coaxial connection and allowing your receiver to do all of the audio processing. Your HK receiver will do a much better job of processing the audio from a digital connection than just about any DVD player would using analog connections.
kaleo said:
And I have no idea what DivX video files are...
DivX is a compression format that is commonly used for sharing videos on the internet. If you don't have a huge collection of these that you want to be able to watch on your TV, then there's no need for a DivX player. Its kind of a niche-market feature that lets computer geeks watch their downloaded TV shows and movies on their TVs without spending hours converting them to DVD-Video
Since you are primarily concerned about the audio quality of a DVD player, and pretty much all DVD players will perform the same (as far as audio goes) if you use a digital connection to your receiver; I'd say go with whichever 5-disc changer you like the best.
since you will be bypassing the audio DACs completely, keep an eye on the video DACs and make sure that they don't go below 8-bit/54MHz. Get a 10-bit/108MHz player if you can. Avoid 27MHz players like the plaque.
