Newbie looking for advice
5
5wallace
I am relative newbie in the Home Theater field, so I was hoping to get some advice. I just got a really nice plasma (Panasonic TC-P50G15) and will soon be getting a blue ray player. I am looking for a relatively inexpensive speaker / receiver combo. I currently live in a small apartment, so a full surround system is out of the question now.
I was hoping to get a receiver and a 2.1 or 3.1 speaker system (small speakers for my small apartment) and to keep the costs 1t $500 or less. I know this is really cheap, but I think I should be be able to find something in this range.
Thanks for your help.
Lordoftherings
Lordoftherings
Hi and Welcome to the Forums.
For the receiver, I can suggest you one.
But for the speakers, you might want to check in the speaker's forums.
* Here's the receiver: http://www.accessories4less.com/make-a-store/item/MARSR5002/Marantz/Sr5002-Receiver-90w-x-7ch-Hdmi-Home-Theater-Surround/1.html
I hope it's not too much money. That will leave you about $200 for two or three speakers.
** But for still less money: http://www.accessories4less.com/make-a-store/item/ONKTXSR576/Onkyo/Tx-sr576-7.1-channel-Home-Theater-Receiver-Black/1.html
*** And to put more money towards the speakers (better quality):
http://www.accessories4less.com/make-a-store/item/MARSR3001/Marantz/Sr3001-Receiver-60w-X-7ch-Home-Theater-Surround/1.html
))) That way, you have a choice, and you can put the money you'd like towards the speakers.
agarwalro
agarwalro
I would recommend staggering your HT purchases a little further.
For now, just get 2.0 with a receiver. Next add a sub and finally center and surrounds.
From what I have read, the Behringer B2030P makes a great bookshelf speaker for the price, $150 pair. Use the remainder of money on a "good fit" receiver from this article, AH Entry Level AVR comparo.
lsiberian
lsiberian
For a receiver get the HK AVR 254 shipped from the HK store on ebay(it's full warranty and a great deal) or used.
For speakers get the Behringer 2031p if you want to skip the sub or the 2030p if you want to add a sub.
For the sub get a Dayton 12"
You'd be set on that. You can go used on the AVR and get something great, but the HK AVR has full blu-ray support and very good amps.
For Blu-ray I use the Panasonic BDP-60 at 130 it's a great deal.
Lordoftherings
Lordoftherings
Speakers to match with the receiver.
Also for some very nice speakers, you should consider the Paradigm Atom Monitor v.6
At $289.88 for the pair, they surely fit your budget.
