Newbie LFE question
reyeskra
I have a Velodyne Impact 10 subwoofer and an integra DTR 30-1 receiver. How do i connect the two together? I only pulled one subwoofer monster cable from my comm closet to the area where my sub will be. But the subwoofer has LFE input left and right?
tcarcio
You only have to use one of the inputs on your sub. It could be marked line in but in any case use one or put a Y splitter at the end of the cable and then to the sub.
GlocksRock
GlocksRock
Consult the owners manual to see if you should use both, and if you only need one, which one they reccomend, although it probably doesn't really make a difference.
Is there one that says LFE or there are left and right? In most cases, it doesn't matter which of the two left or right you use, or use a Y splitter as mentioned.
