From thouroughly browsing this website (forums & articles) over the last several weeks, it appears that this is a subject that's been covered before. However, I'm still confused about what setting might be best starting point for my particular setup, and looking for any recommendations. In general, I'm confused about "Big vs. Small" speaker settings, as well as what Crossover frequency to set the back of my subwoofer to.
My equipment:
1.Yamaha HTR-5550 AV Receiver ("entry level" home theater receiver, Crossover Frequency 90Hz, NOT adjustable)
2.Main speakers: Paradigm Mini-Monitors (rated Low Frequency extension to 40 Hz, Frequency Response +/-2dB rated from 56Hz)
3. Center Channel Speaker: Paradigm CC-370 (rated Low Frequency extension to 57 Hz, Frequency Response +/-2dB rated from 100Hz)
4. Subwoofer: Paradigm PS-1000 (adjustable crossover from 50-150Hz)
5. (No Surround Speakers yet)
My basic question involves whether to set my Main & Center channels to "Big" (thus sending ALL frequencies, including those below 90Hz) or "Small"? Also, where should I adjust the Subwoofer crossover dial to with a specific setting?
Some other things I don't quite understand: 1. What is the harm of sending ALL frequencies to a Center Channel Speaker, when- from my understanding- little Center Channel audio contains low frequencies? 2. Mini-monitors- SMALL size, but seem to me to have decent bass; so what would be the advantage of using them vs. "letting the subwoofer do the work"?
While I'm really looking for "fresh" opinion, here are my current settings: Ctr Channel set to SMALL, Mains set to BIG, Sub set to BOTH. IMO, there seems to be alot of "muffled" mid range, especially when listening to stereo music with this setting. My subwoofer volume is actually set very low (2 of 10 in a very larger room with 22' ceilings)
I'll stop here in hopes that someone reading can make it this far & offer some advice. THANKS IN ADVANCE.
