Hello to all you knowledgeable folks. I am having trouble getting a clear picture out of my Plasma. I have the following components:
Panasonic plasma TH-42PD25
EDTV
Yamaha RX-V100 A/V Receiver
Pioneer DVR-810 H Progressive scan
I have Comcast cable STB ( Set top box )
I have tried wiring all this together every which way but loose.. oh wait , I did loose also. The picture that I get when watching regular cable is very blurry. The confusing part is that when I use the PIP, my little picture looks brighter and way more clear. When I use "split screen" the same thing. The right side is much clearer.
I originally hooked the cable directly to my DVR, leaving the analogue box out, because we get no premium channels, and I wanted to go without the STB if possible. I went from my DVR to my plasma VIA Component. I also ran R/F from the DVR to the Antenna " A" in on the plasma, as I was told that I need to input sources to use my PIP.
Both sources ( R/F in, Component in ) get the same blurry picture.
I then called Panasonic to see what suggestions they had. I was told that running straight R/F to the tv with no STB was the weakest signal I could get. So, I called comcast and had them bring a new STB that gets digital and HDTV quality signals ( At least that's what I was told ) .
I then plugged R/F into STB. R/F from STB to DVR. Component and R/F from DVR to TV. I went back through the "First time set up " with the Plasma, telling it that I now had a STB in the loop.
Guess what? My picture still looks the same.
The only thing I have run to my AV receiver is an optical audio cable so that I can get stereo sound when I want it. I chose this over routing everything through the AV receiver because I dont want to have to use my receiver when I am watching regular tV.
If you read all this, bless your heart.
What am I doing wrong?
DVD playing is very crisp and clear.
I fear that I am not getting the best signal to my Plasma, and I have run out of ideas to remedy it.
Here are some of the other hook-ups I tried:
R/F to STB, Component from STB to Plasma.
R/F from wall straight into Plasma.
All give me the same blurry picture. Football games are horrible to watch. The screen gives me a headache.
My ultimate question to you, How do I get the best picture I can with what I have? Please keep in mind that I have limited knowledge.
thank you
Gary
