Hi, I'm new to this board and really new to Home Theater. I recently bought an Onkyo HTS-770 package system. It's the only Home Theater in a Box I would consider because it looks upgradable. 1000 watts 6.1 surround sound and all speakers are 8 oms.
The receiver appears to be great,and the speakers don't sound bad. I've been told it's a great starter systm, I just need to add better speakers to it.
I've been looking at Bose because a good friend of mine has Bose 301 series V that sound great. He's also using a big Infinity center speaker, sorry I can't remember the model #. He said it's the next step up from the C25. he's also using Infinity bookshelf rear speakers. Watching a movie at his place is something else, and I wanted to duplicate that in my living room.
Rather than just copy someone, I wanted to do my own research. I thought I was sold on Bose 301's, and was in the process of finding out the difference between series IV and series V when I found this forum, and did a Bose 301 search and discovered alot of you don't like Bose.
I'm new to this, and I'm on a budget right now. I want to sell the Onkyo speakers I have and get new speakers. I've looked at the Infinity C25 center channel on ebay and the BIC DV62CLR center channel. I need a good bookshelf speaker like the Bose 301 's because of where I need to put my front speakers, right on top of my bookshelves on each side of my widescreen. It up high so it will not cause interferrence with my TV. If you don't think the 301's are really that good, is there something else that size that will do better?
As far as surround sound speakers, I was considering the Bose 161's due to their size, but now I'm not sure. They will be wall mounted. The Onkyo came with 3 rear speakers. I've been told by a few people to just set up the system as a 5.1 instead of 6.1 for now and turn the rear back channel off.
I may just keep the onkyo rear surround speakers and upgrade the front and center channels. That friend that owns the 301's gave me a subwoofer that sounds way better than the Onkyo subwoofer that came with my system.
Any recommendations for front, center and surround speakers will be helpful.
