Hello folks. I've been into audio systems since the '70s, but as a poor kid, I could never call the gear I had audiophile quality. It never diminished the pleasure of listening to my favorite music though. Currently I have a Sony Win 10 Vaio laptop with an audio card that has always had a noticeable hiss. This irritates me to no end, and has reached a point that I just don't use it anymore. I would like to purchase a setup that will allow me to run the audio out free of the audio card, and that 1/8" jack. The built in speakers are weak and just can't put out the volume I would like. I know I need a DAC and a speaker set. Preferably something with a subwoofer so I can get some decent bass. I'm currently looking at the following speakers .
Edifier S350DB Bookshelf Speaker and Subwoofer 2.1 Speaker System (sorry, can't post links yet)
or
Swan Speakers - M50W - Powered 2.1 Bookshelf Speakers
Will these work?? I have no idea what DAC to look at. There are so many, and also so many with the same features with wildly differing prices. I hate to overspend on something I could have gotten for less. Currently I've been using a long HDMI cable to my AV receiver which works fine, but that's a video/audio cable and I'm not sure if that affects the sound in any way. Plus I have to disable my built in audio to force it to go out to the AVR. I'm not necessarily looking for "audiophile" quality sound here. Good reliable sound is what I want. Also, I'm not sure what using a DAC would require. Is there software/drivers to install to make it work or is this a plug-n-play setup? I assume it's all connected via USB, and that would bypass or negate that audio card hiss issue. Do I have to make configuration changes every time I want to use it, or can I just power it on and play frmo CDs, Windows Media, or Spotify? I'd like one that would allow two things. Output to the speaker set, and output to my home stereo system via the RCA jacks when needed. One more thing...It has to look nice. I just don't like the "black-box" look. So far the Cambridge audio DACMagic Plus is the only one I've found with more than one set of outputs. It's more than I wanted to spend; is this overkill? The DacMagic 100 might be fine and I could just continue to use the HDMI to output to the AVR but I hate the audio config changes. What do you guys think, is there anything I'm missing or any advice you can add? Is there a better, perhaps cheaper way to go? Apologies for being long-winded. Thanks to all. JG
